Occasional Contributor I
clearpass redirecting issue
i connect to clearpass with self registriation , when the register finish and press the login , it will redirect me to https://securelogin.arubanetworks.com/cgi-bin/login
this page it will show me server not found .
please help me on that.
Re: clearpass redirecting issue
Did you change the Captive Portal Certificate in the controller?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
no i did't change any thing in the controller related to certificate
Just as a test, change the "ip address" field in Clearpass to the ip address of the Aruba controller on the guest VLAN.
