config mobility controller and clearpass
I'm trying to connect my Aruba MC 7210 to my ClearPass 6.6 appliance but I get radius error.
1. In ClearPass - I Configured my MC 7210 "\Configuration\Network\Devices\"
2. In MC 7210 - I configured my Radius Server(ClearPass)
"\Configuration\authentication\Servers\Radius Server"
3. In MC 7210 - I configured my Server Group
"\Configuration\authentication\Servers\Server Group"
4. In MC 7210 - I configured my RFC 3576 Server(ClearPass)
"\Configuration\authentication\Servers\RFC 3576 Server"
5. In MC 7210 - I configured my WLAN pointing to Radius Server
And I receive Radius Server Authentication Error. What can I do?
Here we have some logs...
[Th 13 Req 5 SessId R00000005-01-5824b6c9] ERROR RadiusServer.Radius - rlm_service: Service Categorization failed
[Th 13 Req 5 SessId R00000005-01-5824b6c9] ERROR RadiusServer.Radius - rlm_service: Policy Server result = 65535, msg = Service classification failed
[RequestHandler-1-0x7f08245e2700 r=psauto-1478731079-11 h=223 r=R00000005-01-5824b6c9] ERROR Core.ServiceReqHandler - doServiceClassification: Error. Ret code=0 response list size=0
Re: config mobility controller and clearpass
Please post a screenshot of your service.
Tim Cappalli | Aruba Security
OK. Look through the input tab in the access tracker request and make sure
those all match. Also, remove rule 3.
Hi, All this information is correct, I removed rule 3 and is the same
Your SSID rule is likely the issue. You're searching for "secure", but the
SSID is "DigiWorld.Aruba"
Hi, All this information is correct, I removed rule 3 and is the same.
Logs:
Thanks a lot, I solved it and now I get this
ERROR RadiusServer.Radius - rlm_peap: Configured for public mode, but request username hrojas does not match public username public, rejecting
How can I config the Authentication without public mode?
If you're not using EAP-PEAP-Public, remove EAP-PEAP-Public from the
authentication methods list and add EAP-PEAP.
Yes, but I dont't have that choise. Can't I use EAP-MSChap2?
