configuration guide for 6.2 verssion
hi , configuration guide for 6.2 verssion for 6200. i need to know all feature available in this. Thanks & Regards Siav
Re: configuration guide for 6.2 verssion
http://www.arubanetworks.com/techdocs/ArubaOS_62_Web_Help/Web_Help_Index.htm
Contributor II
Are you looking for the config guide for ClearPass v6.2?
Good question.
no. i was looking for all configuration available in Aruba test in my existing setup. this link is not opening.
Trusted Contributor I
go to support.arubanetworks.com, you should be able to get to the documentation without an account.
