connectivity issue in
clients in one specfic group are connecting to the ssid after intermediatelly it is disconnecting also. i am using 6000 controller and ap 135 access point. kindlly tell me which parameters should i check in this issue.
Re: connectivity issue in
- What type of Clients (SmartPhones, Laptops , etc..)
- What type of Authentication are you using?
- What AOS version do you have installed ?
- Can you confirm that those APs are not bootstrapping ? show ap debug counters
- Do you have APs distributed between controllers ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
