Frequent Contributor I
could I integrate Clearpass with Cisco Wireless?
so we have a clearpass installed with a Aruba Wireless solution, so the thing is what about clearpass with cisco wireless integration?
Regards!
hope your coments..
Re: could I integrate Clearpass with Cisco Wireless?
Yes you can. Have you reached out to your ClearPass partner?
Tim Cappalli | Aruba Security
Yes they same that we can integrate it, but don't respond to me if exist a limitation with some Cisco models.
so exist a limitation with cisco models?
Yes, you need to look at the features support matrix on Cisco.com to see in
what release they added certain features. Which features depends greatly on
what you're trying to do.
Thanks!
New Member
Having worked on Cisco wireless previously and now clear pass and Aruba wireless it should work depending on what you want it to do? Clear pass works with Cisco switches no problem and can do radius 802.1x and tacas+ as I have not integrated the two sadly do not have any more information
