Occasional Contributor I
create two SSID's
hi all ,
i have some questions regarding ClearPass:
1- i create one SSID with guest authentication with MAC caching and all thing working fine but how i can set the session time expired for the guests
note : this SSID work with self guest registration page .
2- i want to create another SSID for VIP but with web login what i should configure in controller and ClearPass , i don't think we will do all thing from beginning as per first SSID.
3- how i can install the certificate to make all users using Google chrome to redircting without warning screen .
Re: create two SSID's
please help .
Hey,
1) What is doing the enforcement for the SSID, is this ClearPass? If so have you will need to adjust the Session Length Enforcement Profile you have configured.
http://www.arubanetworks.com/techdocs/ClearPass/6.6/PolicyManager/Content/CPPM_UserGuide/Enforce/EPSession_Restrictions.htm
2) Take a look at the below. Configure a Web Login page as opposed to the Self Registration part.
3) What Operating System is this? There is various methods of distributing a certificate to a client depending on the OS you are running. For example you could install a cert via GPO.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
thank very much for your help .
another small question if want create new field but in this field i want alphabet only without numbers and special character how to make this .
Hey, it looks like the link for the integration guide for 2) was missing so this is below!
Aruba Wireless and ClearPass 6 Integration Guide - Airheads ...
As for the question below, you should be able to do this with a Form Field Validation option.
http://www.arubanetworks.com/techdocs/ClearPass/CPGuest_UG_HTML_6.5/Content/Reference/FormFieldValidationFunctions.htm
http://www.arubanetworks.com/techdocs/ClearPass/CPGuest_UG_HTML_6.5/Content/Configuration/CustomizingFormsAndViews.htm
from this document i cant find the solution there's no role to set all thing in field alphabet only
No answer ?
