create web login for guest operator
dear all,
can we create new web login for only guest operator ?
Re: create web login for guest operator
up
up,
Community Manager
Yes, you can.
Do you want to create a login for view only/guest provisioning or creating guest accounts?
Creating guest account: https://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/Management_Utilities/Guest_Provisioning.htm
Creating MGMT user login:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/What-are-the-different-roles-we-can-assign-to-a-management-user/ta-p/234018
Airheads Community - The best place to Connect. Engage. and Learn.
dear Jamie,
can we create web login for only receptionist sir ?
like receptionist who can only create guest account, he/she will login via web page with another page beside default "https://xxx.com/guest/auth_login.php"
