MVP
creating accounts with expire_after 24h
It appears this should be relatively simple to do but I can't seem to get the thing working as I want it.
The operator must be able to set the date/time the account starts but may not change the account expiry time. This needs to expire 24 after after the account is activated (not created).
To accomplish this I tried creating custom form fields in the operator profile and then change modify_expire_time and expire_after fields.
The guest manual mentions:
- If modify_expire_time is “expire_after” or “expire_time”, then the expiration time is determined
according to the expire_after or expire_time fields as explained below.
-> how exactly? set a string value? change the options generarot or its parameters?
- If expire_after is set and not zero and the account will be activated immediately, then add the value
in hours to the current time to determine the expiration time.
- If expire_after is set and not zero and account activation is set for a future time (schedule_time)
instead of the current time, then the expiration time is calculated relative to the activation time
instead of the current time.
- Otherwise, if expire_after is zero, negative or unset, and expire_time has been specified, use that
expiration time. If the expire_time specified is in the past, set do_expire to 0 and ignore the
specified expiration time.
- Otherwise, if expire_time is not specified, then the expire_time is not set and do_expire will
always be set to zero.
So I tried pretty much any combination of the "modify_expire_time" and "expire_after" form Fields but I cannot get it to work as intended. It keeps complaining: "The expiration time occurs prior to the activation time."
Anyone that can lend a hand with this?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: creating accounts with expire_after 24h
Hi
:smileyhappy:
Read my posts - they contain answers for your questions:
http://community.arubanetworks.com/t5/Guest-Access/CPPM-gt-Can-i-configre-expiry-time-in-minutes-for-example-0-5-30/m-p/78352
http://community.arubanetworks.com/t5/ClearPass-formerly-known-as/How-to-limit-the-expiration-time-of-each-guest-user/m-p/78180
have a lovley night. :smileywink:
me
MVP
Hi Koen
First, if you want to limit this for operators you need to create a new form and limit access to this for the said operators.
You will get some answers in the links from kdisc98, but it won't get you all the way.
  • Go to Configuration -> Forms & Views, select the create-user form.
  • Click Duplicate and edit this to a new name (ie. create-user-24h)
  • Click "Use" to open the form in a new tab to check out which fields you will want to edit.
  • Go back to the create-user-24h form -> click Edit fields
Changes to create-user-24h form
  • sponsor_name -> might want to change this to a read only field with type "static text"
  • modify_expire_time -> disable this
  • expire_time -> disable this
  • expire_after -> change to type static text and initial value to 24
  • do_expire -> might want to change this to hidden and initial value of 1, 2, 3 or 4 depending on what you want to happen at expiration. I normally use 2 - disable and logout
Then go to Administration -> Operator Logins -> Profiles
  • Create a new Profile (or edit your existing) and modify the limitations you want to apply
  • Change Guest Manager settings to Custom, and just leave the form edited above as their only create user form.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
MVP
When you put it like I don't understand why I had issues figureing it out :)
Confirmed working and exactly what I needed so kudos and thanks!
