custom boolean
  • 1.  custom boolean
    MVP
    Posted Jul 17, 2014 09:36 AM
    So I'm trying to configure a session limit that is 4 per default but has one exception.
    Some users need to be able to create a users that either have the default 4 session limit or have unlimited sessions.
    This exception I've got working with a dropdown list that selects either 4 or 0. However I'm stuck trying to create a boolean version of the "simultaneous_use" form field. Ideally the user could tick a checkbox to activate unlimited sessions for this user.
    So, how do I edit the boolean settings so that
    when the box is unchecked it actualy saves a 4 instead of a 1?
  • 2.  RE: custom boolean
    Posted Jul 17, 2014 10:14 AM
    If I understand correctly, you want to display a checkbox on the create guest page.  If checked, unlimited sessions are allowed; if not, the default is used (4 in your case)?
    If so, try this:
    - Set 4 as the session default (Configuration --> Guest Manager)
    - Add simultaneous_use to the Create User form you are using
    - Edit the field (not base)
    - Change User Interface to Checkbox
    - Change Label (maybe something like "Unlimited Sessions?")
    - Change Description (maybe something like "Enable for unlimited sessions")
    - Change checkbox value to 0 (for unlmited)
    This will show the following on the form.  If you check it, unlimited simultaneous sessions is set.  If you leave it unchecked, the default of 4 is kept.
    The result is the following (for checked and unchecked)
  • 3.  RE: custom boolean
    MVP
    Posted Jul 17, 2014 10:22 AM
    Thanks, we missed the default setting in guest manager and changed all our fields to include the simultaneous_use field with a default value of 4.
    With a default of 4 in the checkbox config you can't get it working.
    Anyway, problem solved.. much appreciated!
