do i need to public clearpass when im doing social media login?
I was wondering if i need to do this in order to make social media login works
For example right now im using something like
clearpass.domain.com  this is pointed to a public ip address which is the clearpass
I put that url on the website on social media app developer configuration.
And i also put that url on the url of the controller to point the clearpass..
It works perfectly that way.   I remenber i tried doing it without doing that with azure an didnt work...  I was wondering if maybe i did misconfig something and is really not needed...
Even on the example i have seen on arubanetworks airheads on this they seems that they make public the clearpass but with a name.
Cheers
Carlos
Alternetworks Corp
Re: do i need to public clearpass when im doing social media login?
No, your server does not have to be public facing.
Tim Cappalli | Aruba Security
Tim
On facebook URL where i put the URL of the clearpass
What should i put then?
Right now i got something like https://clearpass.domain.com/guest/facebook.php
Can i use  something like
https://172.16.3.225/guest/facebook.php
Or in what way should i put the url there? so it can work properly
Cheers
Carlos
Alternetworks Corp
You should not be using IP address for anything. Whichever FQDN your clients access ClearPass, should be configured in the cloud providers.
So i just put a fqdn of clearpass even if it point to a private ip and its okay?
Alternetworks Corp
Yes. As long as the client browser can resolve it, you're all set.
Hello Tim i just tried this today again.
It wasnt working before when i tried because the name of the server i had was something like alt_clearpass.domain.local
When you configure that on facebook app you can put it, it accept it but i see that it tells you that is an invalid domain( i think that i didnt see that before) and it wont work... so i took the underscore out, and now it look it as a valid domain and now it works...
so changing it to clearpass.domain.local made it work.
So i guess that when i did the first time it didnt work cause of that and i though in that time that you needed a public domain
Thank you Tim!!
Cheers
Carlos
Alternetworks Corp
Contributor I
It looks like Google will not accept a .local domain.
im just configuring this for a demo, and im stuck in the same thing..
Google wont accept .local...
Alternetworks Corp
Contributor I
Also, Google requires verification..
I have used DNS trickery with the hosts file to get past the URL check. However, how are you supposed to verify that. Seems you can't setup a google POC.
