Regular Contributor II
do you need to have 2 certs (1 for guest and 1 for enterprise)?
Do you need to have 2 certs (1 for guest and 1 for enterprise)?
Re: do you need to have 2 certs (1 for guest and 1 for enterprise)?
If you are NOT using EAP-Termination, then the radius server certificate would be on the Radius server, NOT on the controller.  In that case you would ONLY need a certificate fo the guest, that you would upload to the controller.
