facing an issue in onguard health check with juniper vpn for vpn users.
While login to vpn client, if i put username with domain name appended to it, cppm recognizes that the user is healthy and applies healthy enforcement. However when i login with username without domain appended to it, cppm couldn't find out the previous posture results for the user.
The thing is cppm is saving previous posture results under the username which has domain name appended to it because "enable to use winows single sign on" is enabled under global agent settings on cppm which causes the agent to send username with domain (testdomain\rohan.gosavi) while webauth request, however while sending radius authentication request vpn device just sends username (without domain- rohan.gosavi).
Can we change this behavior of cppm or any workaround?
