Contributor II
fidelio Opera controller integration
hi,
is that possible to integrate fidelio Opera system with aruba controller without clearpass ?
thank you
Re: fidelio Opera controller integration
You could likely make it work with custom code / web services, but nothing
native, no.
Tim Cappalli | Aruba Security
Contributor II
but ,
we can do it clearpass, right?
Contributor II
can we do it with clearpass only, so no need for 3rd party GW,right?
You will need a module on the Micros Fidelio end.
Moderator
Guys,
Just FYI.......
As your also likely aware Fidelio was purchased by Oracle in October of last year. We are in the process of going through an accreditation phase with Oracle. We were in progress before with Micros but have had to re-engage with Oracle post the acquisition. They have had some delays with the process associated with the merger but things are now back on track.
NOTHING has changed regarding our integration its just than we need to re-certify/validate our solution to be apart of the Oracle PMS Eco-System.
Best Regards
-d
ClearPass Product Manager
Contributor II
what model? like nomadix?
Hello Tim
You said that in the Fidelios end need a module
Do the client needs to buy it?
Whats the module name??
Cheers
Carlos
Alternetworks Corp
Moderator
Hi Carlos,
Yes they need to purchase the module..... here is what I have on it........ some of the below might have changed so you need to verify the cost....
  • Oracle Micros http://www.micros.com/
    • Part no: 5009-297
    • Name: Clear Pass Guest – Aruba
    • Type: WWW/IF
    • Cost is set by Micros: Approximately $3500-$4000
Best Regards
-d
