fortigate and external radius authentication active portal
hello every body
I want to make external captive portal using fortigate and authenticate using radius server windows server 2012
I configured the radius server and I have portal in my localhost php
when user want to access internet he will redairect to login page(portal)
 and he will asked to enter username and password after that I must send data to fortigate which will authenticate user by radius server
the question is how can I send data from login page to fortigate and how can I insert new user  into AD radius server  by php
I know the question is very long and very defficult but  I need help
you can see my idea mor clearly in this url
http://cookbook.fortinet.com/using-an-external-captive-portal-for-wifi-security/
Re: fortigate and external radius authentication active portal
Probably best to ask on Fortigate's forums.
Tim Cappalli | Aruba Security
