Contributor II
guest cert issues
I just deployed Clearpass guest with PSK. windows users who were previously connected to Guest and now getting certifiacte warning and want to import a new certificate. How can I resolve this so users are not getting the popup warning?
Re: guest cert issues
Do you have a captive portal configured?
Tim
Tim Cappalli | Aruba Security
Contributor II
yes - sorry left that out
Do you have a public certificate installed?
If clients are attempting to access a secure site, they will likely get the certificate error. Unfortunately there's no way around this.
Tim
Contributor II
The cert its using would be the one under CPPM/administration/certificates/server certs ?
Its a public signed Geotrust cert
Yes. Unfortunately this will happen if users are trying to access a secure website.
Tim
Contributor II
Curious, how is it considered secure?  How do I make this unsecure ;-)
yes I understand the risks
You would have to disable SSL for your captive portal. But you will still get the occasional redirect cert mismatch.
Tim
Contributor II
I have the captive portal on the instant controller to use port 80 and disable https. Is there another location?
In CPG->Configuration->Authentication uncheck "Require HTTPS for guest access"
This will prevent the client from being redirected from port 80 to HTTPS on the ClearPass side.
Zach Jennings
