Contributor II
guest portal not updating endpoint role ID
while logging into guest portal, hitting the mac and user service is not updating the device endpoint with the Role ID. i.e. Guest RoleID = 2.
Need to get those endpoints updated with the guest role ID. ideas?
Re: guest portal not updating endpoint role ID
Did you use the service template?
Tim
Tim Cappalli | Aruba Security
Contributor II
Yes I did
Is there a role assigned in Guest.
Tim
