how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
in cppm ,how do i limit user for reconnect after expirey (1 hour of usage)  for 24 hours? please advise - i'am unable to understand it or make it works for months....
Re: how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
When you create the guest user you will want to make sure the account is valid for 24 hours but only active for one. Clearpass has a black list that it keeps of expired accounts where if the user tries to connect it will deny access to that account.
Its been quite awhile since I have built one.
You will want to use one the following settings that best fits your needs
I believe you will need to use
expiration_time (account lifetime)
expire_postlogin (account active time)
 Ill ping one of the devolopers and see if they can chime in. :)
Thank You,
Troy
Thanks on the info so-far!
IF i need user to be able to create account for 1 hour each 24 hours.
so its:
expration time = 1 hour
and the expire post_login is 24hours?
please advise.
I dont have access to my lab to test localy so I couldn't tell you off the top of my head. I would need to set it up again and test it.
I will try to get some answers in the morning from engineering. Sorry, I wont have access to test until Thurs.:(
Thank You,
Troy
