Regular Contributor II
how to clear DHCP binding for guest
It appears that the leases for the guest wireless is not releasing. What is the command to clear all bindings or at least the inactive ones?
Re: how to clear DHCP binding for guest
clear ip dhcp binding
Thank you
Victor Fabian
Lead Mobility Architect @WEI
