how to create self register webpage on Clearpass Guest and integrate with Micros Vidalio?
I need to create a specific webpage with specific paramters and use Micros Vidilios in transaction process
Aruba
Re: how to create self register webpage on Clearpass Guest and integrate with Micros Vidalio?
You'll need to create a Hotspot Transaction Processor for this:
Then you'll create a Self Registration form with Hotspot option enabled.   Remove all credit card fields and add the first_name, last_name, reservation_number, or room_number fields depending on the setup.
Also, you'll need the software connector from Micros to enable this with ClearPass.   The part number is 5009-297.
AMFX | ACCX | ACDX | ACMX
Thnaks,
But can you clarify what kind of connector as in this document it said Not Released can you give me more information
http://www.micros.com/NR/rdonlyres/E2FF5FCB-3DF7-461B-8A30-EC4FC8C84E7D/0/CurrentCertifiedInterfacesListExternal.pdf
Aruba
I do not have more details, as this is a Micros product.    I don't have any information on the Not Released status that is indicated.  The beginning of the document states the following.  I would reach out to your local Micros and/or Aruba team for details.
Some interfaces below contain a restriction status of Not Released or Restricted. In either case, permission must be obtained from the MICROS-Fidelio Interface Product Manager before the sales of the interface can be facilitated.  Contact the regional MICROS-Fidelio Interface product manager to begin this process.
