how to create ssid with mac based authentication in 6000 controller
how to create  ssid with mac based authentication in 6000 controller.
i have 4 mac address which i should allow.
Aruba
Re: how to create ssid with mac based authentication in 6000 controller
Follow the steps here: http://www.arubanetworks.com/techdocs/ArubaOS%206_3_1_Web_Help/Content/ArubaFrameStyles/MAC_Authentication/Configuring_MAC_Based_Au.htm#mac_authentication_3812164677_1037542
The source database for the authentication can be the controller or an external system.
AMFX | ACCX | ACDX | ACMX
i have done the same . but its not working..& i need to details form start like user role or  user profile
below is my requirement .
1) i have one ssid
2) i need to configure mac based authenation .
3) i need to verify user limit function as well .
Community Administrator
How is it not working?
Can anyone connect or is it locked down completely?
Airheads Community - The best place to Connect. Engage. and Learn.
