how to move ACLs in Whitelist on controller ?
Forgive the extremeley banal and easy question but how do you move ACLs up  in the ACL White List ( under Stateful Firewall -Configuration-ACL White List )  The user guide for ArubaOS 6.4.4.0 does not explain. Ive googled and it states that there are arrows that you can use to move up ACLs but I must be short-sighted because I cannot see them anywhere !!!  Kudos given to quick responses. This is driving me mad.
Re: how to move ACLs in Whitelist on controller ?
You should go to Configuration> Security> Access Control> User Roles.  Edit the User role:
All whitelist entries permit HTTPS and HTTP. Why are you trying to reorder them? It won’t have any impact.
Tim Cappalli | Aruba Security
