Regular Contributor II
how to remove ip address of data interface CPPM?
The GUI keeps spinning and it times out. How can I do it from the CLI?
ip del data -i ??? is not working
Re: how to remove ip address of data interface CPPM?
did it throught the gui. IE isn't good for this task. Chrome did it for me.
