how to upgrade CPPM from 6.1 to 6.3.
Hi All,
I have clearpass server running 6.1.4.55458 and we would like to upgrade them to 6.3. My CPPM server is not online, I need to do it manually.  Is it a direct upgrade or we need to go to 6.2 first to add some partition (casi 01)? Could any one please explain me steps to upgrade the CPPM.
Re: how to upgrade CPPM from 6.1 to 6.3.
Take a look at page 9 of the attached document.
Tim Cappalli | Aruba Security
Super Contributor II
I am currently experiencing an issue with upgrading to 6.3. The VM was originally configured for 6.1 and I'm worried now about the disks and their sizes after reading that particular section - what are the old and new disk sizes and how do I check whats on them?
Read through this thread. Danny provides information on drives.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Release-announcement-ClearPass-6-3-0-is-now-available-PLEASE/td-p/133035
Thank You,
Troy
