Occasional Contributor I
iOS OnBoarding issue
I've been trying to search the boards for resolution but without luck.
I have two SSIDs, one for onboarding and one for actual 802.1x. Android and Windows devices are onboarding just fine and automatically connecting to the 802.1x SSID. My issue is that iPad 2 (using the same service for 802.1x) downloads, installs, etc. the cert correctly but when connecting to the 802.1x SSID it says "can not join network".  When I check the access tracker it states that the device is trying to log in using <username> and not the <username:seq:mdps_generic> which is listed in the OnBoard Devices repository.
The certificate is 2048b and generated in OnBoard. ClearPass is 6.0.2 and Aruba WLC 6.1.
Any ideas how to get the iOS onboard working as smoothly as the other platforms? Any advice greatly appreciated, thanks!
Re: iOS OnBoarding issue
Make sure you have EAP-TLS configured as an authentication type in the service.
<username> means that the IOS device is using TLS.  <username:seq:mdps_generic> means that you are using EAP-PEAP.
Thanks for the prompt reply!
Please see the attached image from access tracker. In the matching service "BYOD 802.1x test" I have methods:
1. [EAP PEAP]
2. [EAP FAST]
3. [EAP TLS]
4. [EAP TTLS]
Should the iPad be using the <username:seq:mdps_generic> from Onboard devices repository? In my BYOD 802.1x test service I have only [Onboard Devices Repository] and nothing more as Authentication Sources.
What does it say under the Alert Tab?
Error Code:
201
Error Category:
Authentication failure
Error Message:
User not found
 Alerts for this Request
RADIUS[Onboard Devices Repository] - localhost: User not found.
EAP-TLS: Authentication failure, unknown user
Is there anything in the onboard device repository?
Yes, please see the attachment. In OnBoard the device has also a valid certificate:
Issued to: test-ipad
Issued by: ClearPass Onboard Local Certificate Authority (Signing)
I would delete that and re-onboard your ipad.
That is a PEAP credential, not a TLS credential.
Thanks for the advices, I already tried to reprovision the device and it did not help. Same issue also with iPhone 3.
See the attachment of OnBoard network settings. On the authentication tab I have "certificate" selected for iOS and OS X 10.7
I would delete the existing certificates that correspond to the Ipad and reprovision.
