iOS using Chromecast with IAP-225 for Netflix
This has stumped me for a while, and I'm not exactly sure if it's related to the Aruba cluster, or if it's an issue with Netflix/Google/Apple/etc.
I got a company phone not to long ago, which was an iphone, I was previsouly and android person (still am) and all of the settings I normally enable for customers to use chromecast are enabled, and verified working, since my androids had no problem streaming. But for the life of me, I can't get my iPhone to stream anything, or even detect the chromecast. The google Home app, sees the chromecast, but it doesnt pop up in any apps to use it.
I am running 6.5.2.0 on a two AP cluster of IAP225's, All Airgroup services enabled, using a 2.4GHz only SSID for the chromecast, client match is off, DMO, MTO and broadcast filtering are disabled.
Re: iOS using Chromecast with IAP-225 for Netflix
See if there are any blocked queries or service id's:
http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#CLI_commands/show_airgroup_cppm_entries.htm?Highlight=blocked
Frequent Contributor I
Check out this other airheads thread:
http://community.arubanetworks.com/t5/Security/why-will-chromecast-work-with-everything-but-from-an-IOS-device/m-p/249359
Mike Davis
Network Engineer
University of Delaware
Aruba# show airgroup blocked-queries
AirGroup dropped Query IDs
Service ID #query-hits
_sleep-proxy._udp 2317
_fb._tcp 214
urn:smartspeaker-audio:service:SpeakerGroup:1 63
_samsungmsf._tcp 12
4d690594._sub._apple-mobdev2._tcp 7
uuid:93a437b3-1f9d-45cd-8062-b49593567fdb 2
uuid:b54e570b-0066-cc15-2a67-4fb7d7f1ded4 2
uuid:59c79254-64c0-17a6-2651-3b65f28de8ac 2
uuid:10225311-3009-2000-0000-7ced8dc373ff 2
uuid:fa92731b-bedb-459a-88bf-fa90a5698a7f 3
Num dropped Query IDs:10
Should I just create a new service for those and hope for the best?
I still would like assistance with this. I have not found a workaround.
Same problem occurs with the 103. I solved the problem for my network by changing the broadcast filtering setting within the SSID WLAN settings. (after i did all the things mentioned in this thread)
Go to your virtual controller and edit your SSID, click on "advanced setting" -> WLAN settings tab -> change the setting for "broadcast filtering" to "disabled" (instead ARP)
Good luck!
