Contributor II
importing authentication source issue
hi,
i am trying to import authentication source from another cppm to my cppm,
when i export it from old cppm i didnt type password for it,
no when i am tryin to import it to my new cppm it asking for logging password, the 2 cppm have same login password ,
here is the error screen shot attached
thanks
Re: importing authentication source issue
Modify the xml file to include the password before importing it.
Tim Cappalli | Aruba Security
