ldap over ssl port 636
if the validate certificate is not ticked, do I still need to install the ldap cert into clearpass trusted list?
Regular Contributor II
Re: ldap over ssl port 636
No - this should only be required if the validate certificate box is checked under the authentication source.
David
ACDX #98 | ACMP | ACCP
