location "Building1.floor1"
How do I set or change the "location" of the running config?  (location "Building1.floor1").  Or just get rid of it all together.
Re: location "Building1.floor1"
If you wish to remove the location then select "remove fqln" when provisioning the AP. if not enter the buildings/floors in visualrf and update accordingly.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
MVP
If you mean the controller location, you can change this through the GUI via:
Configuration > Network-Controller> Look for the controller location setting in here.
Via the cli just enter the following command:
configure terminal location "whatever you want here"
Koen (ACMX #351 | ACDX #547 | ACCP)
