Having trouble with the following requirement:
A Guest Account should get disabled after 14 days if it is not used.
The Life time options are 1, 2, 3, 4, 5 days.
The service is based on the "Guest Authentication with MAC Caching" template.
If guest logs in durcing the first days with "5 day account" the expire_time gets modified to today +5 days which is perfectly fine
BUT
If guest logs in on the 13th day (of this 14 day period) with "5 day account" the expire_time remains the original value which was set during creation. Which means it gets not updated and guest can use his account just 1 day.
My Customer would like to see the expire time get enhanced automatically in this case.
To be honest, i do not get why it is not getting updated altough the Access Tracker states that.
Does anyone have an idea or solution for this requirement?
best regards
Kevin
