My aruba controller is not opening CLI via SSH, SSH is enabled on the controller and controller send the requests to ACS also for the user Auithentication but still not accepting the connection. telnet and GUI works fine.
while ran debug for aaa got nothing in the logs still it refuses the connection via SSH.
Checked the internal firewall Port 22 is allowed.
need help , I have similar problem in othere 6 controller all are having same code running on .
ArubaOS (MODEL: Aruba7210), Version 6.4.2.14
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-11-24 at 14:29:20 PST (build 52696) by p4build
ROM: System Bootstrap, Version CPBoot 1.2.3.0 (build 43722)
Built: 2014-05-13 10:03:12
Built by: p4build@re_client_43722
Switch uptime is 132 days 19 hours 59 minutes 43 seconds
Reboot Cause: User reboot (Intent:cause:register 78:86:50:2)
Supervisor Card
Processor (XLP416 Rev B2 (Secure Boot) , 800 MHz) with 7229M bytes of memory.
32K bytes of non-volatile configuration memory.
7744M bytes of Supervisor Card system flash.
