Frequent Contributor II
on wired 802.1x how to make users keep working if clearpass fail?
I'm integrating clearpass with cisco NAD switcches 2960,3650,samll bussiness now the ting is that customer want the users to keep working normally in case of clearpass total failuer ,so what is the best thing to do to achive that ?
Re: on wired 802.1x how to make users keep working if clearpass fail?
802.1X cannot fail open. You would have to configure the switch to have an open fail through VLAN which is not very secure.
Tim
Tim Cappalli | Aruba Security
interface GigabitEthernet1/0/18
switchport access vlan 100
switchport mode access
switchport voice vlan 110
authentication event fail action next-method
authentication event server dead action authorize vlan 100
authentication event server alive action reinitialize
authentication host-mode multi-host
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
dot1x pae authenticator
dot1x timeout server-timeout 30
dot1x timeout tx-period 3
dot1x max-req 3
dot1x max-reauth-req 3
spanning-tree portfast
Thank You,
Troy
So tarnold this will make useres able to work normally in case of Clearpass total failuer on VLAN 100 right?
Yes. The line dead server is the vlan the port would default to. Just like Tim stated its not a very secure action but it is an option.
Thank You,
Troy
so you mean that user who still didn't enter his 802.1x credinital have access to the network  ???
Just like the line states.
If the radius server is dead or the switch looses communication within its timeout period it will just role over to vlan 100.
Thank You,
Troy
Dear Tarnold when I used this configuration the 802.1x pop didn't came and the ethernet adapter on the client keep saying attempting to authenticate and doesn't show any pop up to enter credentals
when I added this line it worked after 30 Sec :
#authentication event no-response action authorize vlan 100
but this is working well for pinging inside network but for windwos domain lit is not working liek (opening FTP) or remote desktop connection all not working so how to solve this?
That is all dependent on your switch and your VLAN settings. You will need to contact the switch vendor.
Thank You,
Troy
