Regular Contributor II
onboard device lincese
Hi Forum,
For onboarding laptops, can someone confirm the number of onboard license consumed when onboarding a laptop? usually a laptop has a wired and a wireless mac address and I want to check and see the count consumed. Is it 1 or 2 license count? I know it is a single cer issued to the laptop
thanks,
Re: onboard device lincese
It’s per certificate. The certificate can be used on any network interface on the device (wired, wireless, VPN).
If the wired connection is present during Onboarding, both the wireless and wired MAC addresses will be embedded in the certificate (if the MAC address is available)
Tim Cappalli | Aruba Security
Thanks Tim.
so,
One license per device regardeless of your NIC-MAC address?!
One license per certificate. :)
