[onboard device repository] is NOT chosen as authentication source after onboarding window PC
i'm testing CPPM 6.5 onboarding with the provided templates (3 services).
Andirod and iOS worked find as using EAP-TLS.
But the windows mechine failed the second RADIUS authentication after provisioning. QuickConnect uses PEAP and MSCHAPv2 for windows and CPPM didn't choose [onboard device repository] as the authentication source although it has been configured in the service. Instead, it uses the AD with the unique credential, 'username:26:OnboardDevice' as full username in my case, and it fails...
RADIUS return Err 216.
RADIUSMSCHAP: AD status:Logon failure (0xc000006d)
MSCHAP: Authentication failed
EAP-MSCHAPv2: User authentication failure
on the onboard side, i've seen the device been onboarded and cert has been issued.
anyone has the similar problem and know how to solve this?
Re: [onboard device repository] is NOT chosen as authentication source after onboarding window PC
What version of Windows? It looks like you're using the unique credential option which is PEAP.
Tim
Tim Cappalli | Aruba Security
Windows 7 Service Pack 1
it's recognized correctly on the onborad side.
but it show
Radius:Aruba:Aruba-Device-TypeWin XP
on the policy manger side.
i think the unique credential option - PEAP for windows is the default configure.
when i changed it to TLS, it works fine.because it always hit the first enforcement conditions, which just check the authentication method.
below is my 802.1x service configure, which is pretty much the default.
anyway, PEAP should work as well...
Can you post a screenshot of the access tracker request tabs?
Try removing the strip username rules from the authentication tab and see if
it works. Onboard unique credentials are not design to have a UPN. If that
ends up working, you'll have to tweak your SQL queries.
yep! it works without the strip username rules.
it's just a testing environment but it's good to know the trick.
would this be improved in the future release?
anyway, thank you Tim for your help and quick response!!
Unique PEAP credentials generally aren't used anymore. If you want to use them, you'll need to modify the SQL query on onboard device repository to use Full-Username instead of Username.
Tim
