o.k. next problem and for me its due to a lack of info in the clearpass online help.
It seems that for Oracle I need to supply a service name somewhere but I don't know where I put it in the available clearpass fields and theres nothing in the online help other than "use these fields for a generic sql service"
The error message I get is
ORA-12514: TNS:listener does not currently know of service requested in connect descriptor
Cause: The listener received a request to establish a connection to a database or other service. The connect descriptor received by the listener specified a service name for a service (usually a database service) that either has not yet dynamically registered with the listener or has not been statically configured for the listener. This may be a temporary condition such as after the listener has started, but before the database instance has registered with the listener.
Action:- Wait a moment and try to connect a second time.
- Check which services are currently known by the listener by executing: lsnrctl services <listener name>
- Check that the SERVICE_NAME parameter in the connect descriptor of the net service name used specifies a service known by the listener.
- If an easy connect naming connect identifier was used, check that the service name specified is a service known by the listener.
- Check for an event in the listener.log file.
Well at least its a step forward :-))
