Hi
I have a problem with ClearPass Guest
I am able to get to the Clearpass Guest Login page
However once I click login the page just reloads (with no error messages)
No messages show up in access tracker
I also do not see Radius request using wireshark
However if I leave pre-auth checked on the web login page
I do see the accounts details appear in access tracker
but with authentication failure 204
It seems that there is no Radius Request been submitted after clicking login
I did also test using an "employee" SSID with ClearPass connected
to AD and that works 100%
some details on setup:
network
Flat layer 2
IAP using VC virtual IP: 192.168.100.214
ClearPass IP: 192.168.100.211
Controller:
IAP 205 VC - Version: 6.5.0.0-4.3.0.2_57688
default certificate
securelogin.arubanetworks.com
setup as per setup Guide and videos
I have checked
Captive portal profile -
hostname URL
I have tried with pre and post auth roles and unrestricted
ClearPass
default certifcates for Radius and HTTP
Tried multiple services (but cant see how that can be the issue
as I am not seeing anything in access tracker)
Configured IAP VC as the NAS device
Under Guest setup:
created Guest account
created Web login page left everything as default
used securelogin.arubanetworks.com as the address which resolves to 192.168.100.214
I do have internet breakout
any other ideas please?
thank you
