Regular Contributor I
problems with onboarding android devices
we are using Clearpass 6.5.5 and I test the CP Onboarding funktion.
I´ve configured singe ssid onboarding, it all works fine with my windows laptop, but my andoid mobile phone have some problems.
I conntect to the ssid with my ad credentials I got redirect to the provissioning page, I insert my credentials again cppm says in access tracker accept, the page is loading an I got the message in the mobile phone browser, your session has expired.
have anyone an idea what´s the problem?
Re: problems with onboarding android devices
It was a browser problem with android google chrome browser.
Leon,
did you just use a different browser to resolve this problem?
Thanks!
Occasional Contributor I
In my experience, WLC will drop the client session, if the ACL is not allowing to go to Google play store or to download the app via Google content delivery network . I would suggest either (1) pre-download and pre-install Cisco NSA app using another WLAN or connection or (2) update the ACL. CCleaner Happy Wheels VLC
