Frequent Contributor II
radius and certificates
Hi ,
I am implementing 802.1x for a ssid.
AD on one windows 2003 server ( Root CA ) and IAS on other machine.
Now where do I need to install certificate ( I guess on IAS enabled machine) and which certificate (ROOT CA or I have to request a certificate from root CA for IAS enabled machine)??
Also on Windows XP client I have to select Validate server certificate ?
and which certification authority I have to check ? Do i need to install Root CA first on XP client then I will Get option for selecting my Certificate Authority ?
Re: radius and certificates
check the thread here:  http://community.arubanetworks.com/t5/Authentication-and-Access/Step-by-Step-How-to-Configure-Microsoft-IAS-Radius-Server-from/m-p/14391/highlight/true#M80
You also might try searching for Windows 2003 in case you have any issues.
Thanks for your reply..
I have implemented radius but need some clarity regarding the certificates part...what kind of certificate should be present on IAS enabled machine ?
Moderator
Hi
Your IAS server should have a Server Certificate, and clients should validate that the server certificate (presented by the IAS server) is signed by your CA.
Regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Now, I have AD and CA on one Windows 2003 server. (server 1)
IAS enabled on second server . To obtain certificate for IAS enabled server , in Internet Explorer I have put  <server1 IP>/certsrv
which certificate is to be installed >> there are two options 1. request a certificate  2. Download CA certificate >>> what to select ?
Also on client laptop CA certificate is to be installed ?
1.  Request a Certificate.  Computer Certificate.
2.  Client does not need one distrubuted in this manner.
thanks colin,
one last question,
Following is XP client config Is it correct,
TestCA is my Root CA and after installing on this XP Client I got the TestCA checkbox...is it required....or
or we can just tick Validate Server Certificate box and leave 'Trusted Root CA 'unchecked...
Not required, but it locks it down so that your client will only connect if the radius server it authenticates to has that CA certificate.
