Frequent Contributor I
replacing controller breaks authentication
setup : controller 650 authenticates using Clearpass 6.3.0.60537.  Everything works perfectly.
Now :
1. backup config
2. get a new controller 650
3. restore config
4. bring controller up (same settings as previous controller thus)
Now authentication fails (we get web authentication fails after using the guest portal).  Is there something cached or saved in Clearpass regarding the controller device (something based on the mac address)?  Only thing i haven't tried is rebooting Clearpass or removing/adding the controller device back in Clearpass.
5. activate original controller back -> authentication works again...
Re: replacing controller breaks authentication
pnobels,
I would look at Monitoring> Event Viewer in ClearPass to see if CPPM is not getting radius traffic from the ip address that it expects.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Are you using the same IP addresses on the new controller?
Sent from Windows Mail
Tim Cappalli | Aruba Security
Nothing is cached. It's all based on the Nas ip, name or SSID
Double check your password on the radius settings on the controller.
Look in the event viewer of CPPM to see if there are any errors.
Thank You,
Troy
can't see anything unusaul in there. I can see the request coming in
access tracker, with the expected ip...
Kind regards,
Peter Nobels
*Peter Nobels* | System Engineer Business Information Systems & Solutions
(BISS)
T +32 3 250 56 41 | M +32 470 89 26 54 | nobels.peter@deme.be
*DEME nv | Dredging, Environmental & Marine Engineering*
No, other IP. Haven't been able to perform any further testing. My
collegue had to return the controller.
Kind regards,
Peter Nobels
(BISS)
Problem solved :)
