Regular Contributor I
shutdown clear pass
Hi! :smileyvery-happy:
While I read the user guide, I have read that to shut-down the policy manager, I have to do an access with these credentials
Username: poweroff
Password: poweroff
So i wish to know if exist another method and if i can disable the method that i explain to you.
because so if someone can reach my policy manager via ssh can shut-down it.
thanks.
Andrea
Re: shutdown clear pass
Username: poweroff
Password: poweroff
thanks.
According to the user guide that username and password is only available through the serial console.
Colin Joseph
Aruba Customer Engineering
Aruba
cjoseph is right; that logon should not work through SSH.
Other methods:
CLI:
system shutdown
WebUI:
- Administration --> Server Manager -->  Server Configuration --> Shutdown button
ACCX | ACDX | ACMX
