signal issue trouble shooting
hi , i am using controller based setup . access points live. but signal strength is poor . what parameters should i check for signal issue in a paricular access point and hoe can i reslove this .
Re: signal issue trouble shooting
"show ap active" will tell you what power.
What are you using to measure signal strength?
Super Contributor I
If you have a client connected you can go to Dashboard -> Clients and take a look at their SNR to see how well the client is doing in that area.
ACDX #419 | ACMP |
not client connecity issue  access point  coverage is poor how i can troubleshoot this.
