Super Contributor II
steps required to upgrade clears cluster from 6.4.1 to 6.4.2
Now that CPPM 6.4.2 is out, what steps are required to upgrade a 5 node CPPM cluster from 6.4.1 to 6.4.2?
Rgds
Alex
Aruba
Re: steps required to upgrade clears cluster from 6.4.1 to 6.4.2
Please review the section titled "Updating to a Patch Release from an Earlier Release" in the Release Notes:
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=15559
You'll need to upgrade your publisher first; then the subscribers.
AMFX | ACCX | ACDX | ACMX
