Occasional Contributor I
trying to copy flashbackup files off a controller using FTP and it wont work
Re: trying to copy flashbackup files off a controller using FTP and it wont work
Error message?  What ftp server are you using?  Can you copy anything else to that FTP server?
We don't have any information to help you.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Frequent Contributor I
Did the ftp command change in ArubaOS 6.4?  I just noticed our backup script stopped working since it was using the syntax:
copy flash: flashbackup.tar.gz ftp: FTPHOST USER PASS DIRECTORY
and now the PASSWORD must be entered on a separate line
copy flash: flashbackup.tar.gz ftp: FTPHOST USER DIRECTORY
Password: PASS
Is there a way to get the old behavior?
Mike Davis
Network Engineer
University of Delaware
85MikeTPI,
We can check on that.  What controller platform are you using?
I have M3 master and 7240 locals.
Mike Davis
Network Engineer
85MikeTPI,
Thanks for your patience.  The change was deliberate, because the previous behavior exposed the FTP password on the commandline in the clear.  The new way, it idoes not, and we thought the change was important mainly because of that:  We did not want someone looking over someone else's shoulder and be able to see their FTP password.  We are working to get this change highlighted in the release notes/6.4 documentation so that it is obvious.  Thank you for bringing it up.
