unauthorized users have network access due to switch fail-open
I configured the switch to fail-open if the communication with CPPM lost, but I got the unauthorized users have access to network due to this setting.
If someone have 802.1x enabled on his adapter and connected his PC to network, then the conencted switch port will start looking for the authentication server, but since the authentication will fail for this user, then and due to the "fail-open" action in switch port, the port will be assigned to the data VLAN and he will have network access.
So is this logic, or it must be setup in different way?
Mahmoud
Re: unauthorized users have network access due to switch fail-open
What type of switch?
Tim Cappalli | Aruba Security
We have Juniper switches as below port settings
set protocols dot1x authenticator interface ge-0/0/31.0 supplicant multiple
set protocols dot1x authenticator interface ge-0/0/31.0 transmit-period 5
set protocols dot1x authenticator interface ge-0/0/31.0 mac-radius
set protocols dot1x authenticator interface ge-0/0/31.0 reauthentication 86000
set protocols dot1x authenticator interface ge-0/0/31.0 server-timeout 3
set protocols dot1x authenticator interface ge-0/0/31.0 maximum-requests 3
set protocols dot1x authenticator interface ge-0/0/31.0 server-reject-vlan Quarantine-VLAN
set protocols dot1x authenticator interface ge-0/0/31.0 server-fail permit
Mahmoud
when a guest "unauthorized" who has .1x enabled in adapter connect to switch port, I can see in CPPM logs sending deny access message to switch, but the switch port dot1x logs show that port inherited the switch port "fail-open" action
Mahmoud
Is this controlled through ClearPass or its totally related to switch?
If its related to clearpass, then is the interchange between reject and drop actions for the unauthorized users going to make difference?
Mahmoud
It's a switch configuration
Contributor I
Configure 802.1x with MAB auth and set deny role as default for mac auth poicy. With above configuration switch will attempt to authenticate client with 802.1x and if client dont have 802.1x setting then it look for mac auth so CPPM will assign deny role as per policy. If cppm connection lost with NAD then switch will assign failed open vlan to client.
Milind Yashwantrao
