Frequent Contributor II
what is the deference between enabling AD attribute as role or as attribute?
I can see that I can Enbale in AD attribute for example Departmnet as a role or as attrbute or both so what is the deiffrence and what scnarios can be driven from this both checks?
Re: what is the deference between enabling AD attribute as role or as attribute?
Role is mapped directly to a role without a role map.
Tim
Tim Cappalli | Aruba Security
So if I enable IT DEPT as a role this doesnt need role mapping?
Yes, for example if Department = NetOps, the user are automatically tagged with the Role name NetOps in Clearpass.
PS: Roles in clearpass are independent of User-Roles on the Aruba Controllers.
Thanks for clearing up so you say thet roles section in clearpasss is Only for aruba Controller firewall roles only??
Yes just for the ClearPass side.
ClearPass role != controller role
Tim
MVP
Think of it this way:
Clearpass role: just a label
Aruba user-role: firewall policy
Koen (ACMX #351 | ACDX #547 | ACCP)
You guys are awsome I really learn alot from you and thank you so much for clearing things up and Hope to be like you
