Contributor I
when I should use Single SSID and Dual SSSID On boarding?
When I should Use Single SSID onboard and when should I use Dual SSID onboard?
Re: when I should use Single SSID and Dual SSSID On boarding?
If you are using a publicly signed RADIUS server certificate, you can do single.
If you are using a self-signed, Onboard CA signed or internal PKI signed RADIUS server certificate, you need to use dual SSID onboard.
Tim Cappalli | Aruba Security
You use single SSID when your are in Tunnel mode. You use dual SSID when you are in bridge mode.
