will my aruba controller will support 802. 11 u %26 if not i want to update what is process
hi ,
i have 6000 controller . will it supports 802.11 u. if not is it possiable to upgrade the software . pls suggest me.
Re: will my aruba controller will support 802. 11 u %26 if not i want to update what is process
Yes, Hotspot 2.0 is fully supported starting in AOS 6.3. It is not a hardware dependent feature.
Tim Cappalli | Aruba Security
Yes, Hotspot 2.0 is supported in ArubaOS. It is not dependent on hardware.
