Contributor I
wired onboarding with HP switch..
hello,
We have HP 5500 series switches and want to achieve onboarding. please help with commands which will go on HP switches and attributed i need to add in CPPM for pre-provisioning and post-provisioning role.
thanks in advance
Re: wired onboarding with HP switch..
This should be a good start for you:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17690
Tim Cappalli | Aruba Security
