Contributor I
wpa2-ent getting slower connection than wpa2-psk
I had recently setup wpa2-ent authentication and is testing it with small group of user. I found out that during peak usage, user connected to ent ssid getting really slow connection and taking long time to load a page. Another machine that sitting side by side with it connected to psk ssid is much more faster. I do no remember that i have set any bandwidth control for any ssid. Is there a way to pioritize ent ssid or fix it?
Re: wpa2-ent getting slower connection than wpa2-psk
Upgrade the drivers on the devices that are having issues.
