Software Defined Networking (SDN)
POE PROBLEM
hi all,
i'm using aruba switch S1500 24P to connect and power Ruckus APS R500 , the  "poe-factory-initial" is enabled and affected to all interfaces but the APs didn't get the power , also i have configured a POE profile and affect it to interfaces the same problem appear.
asking for your help.
thanks,
Amine.
