Software Defined Networking (SDN)
need help?
I'm looking for a branch SDWAN solution that can terminate 2 separate broadband connections from different ISPs for redundancy. Can the RAPs do this? If not, what is an alternative Aruba solution to provide redundant ISP connections on the same device?
Re: need help?
The branch office controllers are the more appropriate fit when dual ISPs are needed.
Charlie Clemmer
Aruba Customer Engineering
